Введение
If the user would like to replace a faulty cooling fan, or one that running too loudly, this guide will give step by step information on how to achieve this.
Выберете то, что вам нужно
Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
Place your hands on the plate and pull it toward yourself.
The plate will pop out of place and may then be removed.
The cooling fan is located near the edge of the device, on the side with the vent, and is contained within a plastic shroud.
Unscrew the two 9mm Phillips #1 screws that secure the fan in place.
Disconnect the fan header from the motherboard of the laptop.
2 человек успешно провели ремонт по этому руководству.
