Введение
If the user would like to reapply faulty or low quality thermal compound, this guide will give step by step information on how to achieve this.
Выберете то, что вам нужно
Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
Place your hands on the plate and pull it toward yourself.
The plate will pop out of place and may then be removed.
The cooling fan is located near the edge of the device, on the side with the vent, and is contained within a plastic shroud.
Unscrew the two 9mm Phillips #1 screws that secure the fan in place.
Disconnect the fan header from the motherboard of the laptop.
The system's heatsink is the copper pipe and large metal assembly held down by five screws.
Remove the five Phillips #1 screws in the order numbered on the metal assembly.
The screws are self-retaining, meaning they will stay connected to the heatsink and will not fall out from the assembly.
After all screws have been unscrewed, the heatsink can be removed.
The thermal compound is the gray material that sits on the heatsink and CPU surfaces. In order to apply new compound, the old compound must be removed
Use a cotton ball or swab and apply rubbing alcohol until it is moist but not dripping.
Scrub the heatsink surface with the cotton ball until all thermal compound is removed.
Reapply alcohol to a new cotton ball or cotton swab and repeat Step 9 for the CPU surface.
To reassemble your device, follow steps 1-7 in reverse order.
4 участников успешно повторили данное руководство.
Один комментарий
Great post and i followed the mentioned steps. Now, my cpu heat rate low down to 20%. thanks for such a wonderful article. Happy Fathers Day to all of you.
