Введение
Follow this guide to replace the keyboard to the Dell Latitude E6330
Выберете то, что вам нужно
Start by flipping the laptop over and removing the two, deeply recessed, 2.5mm x 5mm screws from the bottom face of the laptop.
Grab a plastic spunger and slowly pop out the keyboard bezel from around the keyboard.
Locate and remove the remaining three 2mm x 3mm screws connecting the keyboard to the frame. (One is located just left of the left mouse button and the remaining two are just right of the right mouse button).
At this time you should be able to gently lift the keyboard off of the frame and expose a ribbon cable connecting it to the motherboard. Flip up the clip holding the ribbon in place and remove the faulty keyboard.
2 участников успешно повторили данное руководство.
