Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Dell Latitude E6400 WiFi Card Replacement
Выберете то, что вам нужно
  1. Dell Latitude E6400 WiFi Card Replacement, WiFi Card: шаг 1, изображение 1 из 2 Dell Latitude E6400 WiFi Card Replacement, WiFi Card: шаг 1, изображение 2 из 2
    • Simultaneously slide the battery latches (outlined by the red box) to the dock connector in the middle.
    • This will release the battery. Just slide the battery away from the computer.
    • Open up the computer and press and hold the power button for 5 seconds. This drains any power left inside the computer.
    • This is important, as if electricity remains in the notebook, it can shock you and damage the logic board.
  2. Dell Latitude E6400 WiFi Card Replacement: шаг 2, изображение 1 из 2 Dell Latitude E6400 WiFi Card Replacement: шаг 2, изображение 2 из 2
    • Loosen the center screw with a philips screw driver. This is the only screw that needs to be loosened.
    • It can't be removed as it is captive the the bottom plate.
    • Now slide the plate away from the dock connector.
  3. Dell Latitude E6400 WiFi Card Replacement: шаг 3, изображение 1 из 2 Dell Latitude E6400 WiFi Card Replacement: шаг 3, изображение 2 из 2
    • Use a plastic opening tool or a spudger to remove the antennas.
    • I use my fingers, but the picture shows and iPod opening tool because most adults have bigger fingers.
    • I'm 14, so my fingers are small enough.
    • Some E6400 models have a card with three connections-a gray wire in the middle-marked appropriately.
  4. Dell Latitude E6400 WiFi Card Replacement: шаг 4, изображение 1 из 1
    • remove the one and only philips screw securing the WiFi card in place.
  5. Dell Latitude E6400 WiFi Card Replacement: шаг 5, изображение 1 из 2 Dell Latitude E6400 WiFi Card Replacement: шаг 5, изображение 2 из 2
    • The card should instantly pop to an angle less than 45 degrees once the screw is removed.
    • Now simply pull the card strait away from the slot.
    • Install a new card by sliding it in the direction of the arrow and pressing firmly down until it clicks.
  6. Dell Latitude E6400 WiFi Card Replacement: шаг 6, изображение 1 из 2 Dell Latitude E6400 WiFi Card Replacement: шаг 6, изображение 2 из 2
    • Slide the bottom plate on.
    • Slide it to the rear of the notebook. (battery compartment)
    • Tighten the screw.
    • Do not over-tighten. Doing so will strip the screw.
  7. Dell Latitude E6400 WiFi Card Replacement: шаг 7, изображение 1 из 2 Dell Latitude E6400 WiFi Card Replacement: шаг 7, изображение 2 из 2
    • Slide the battery in until it clicks.
    • Press the power button.
    • AND it works.
Заключение
12 участников успешно повторили данное руководство.
Nicholas Ouimet
Участник с: 10/16/09
3 479 Репутация
Автор 12 руководств
Один комментарий
Why is your soundcloud linked as the wifi card site. It is really not appropriate considering how great of a job you did with the instructions for this repair.
Sean Brewer - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 32
За всё время: 28,464
