Введение
This guide will step you through the process of replacing your cooling fan.
Запчасти
No parts specified.
  1. Lay your laptop upside down on your desk. Remove the battery.
  2. Remove the following 5mm screws. Loosen the middle 5mm screw.
    • Remove the following 5mm screws.
    • Loosen the middle 5mm screw.
  3. Remove the back cover by sliding it downwards.
    • Remove the back cover by sliding it downwards.
  4. Unscrew the following 2mm screws. Remove the fan case.
    • Unscrew the following 2mm screws.
    • Remove the fan case.
    • Do not pull hard enough to break the wires connected to the motor.
  5. Unscrew the 1mm screws on the fan case.
    • Unscrew the 1mm screws on the fan case.
  6. Remove the fan by pulling it away from the motor.
    • Remove the fan by pulling it away from the motor.
Заключение
Stephen Tate
Участник с: 06.11.2017
538 Репутация
Автор 4 руководств
Команда
Baylor, Team S8-G2, Johnson Fall 2017 Member of Baylor, Team S8-G2, Johnson Fall 2017
BU-JOHNSON-F17S8G2
1 член
Автор 4 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 1
За 7 дней: 3
За 30 дней: 35
За всё время: 752
