Введение
The backplate can crack and expose the hardware it protects. This guide will show the user how to replace the backplate.
Выберете то, что вам нужно
Push the tabs on the left and right of the battery out towards the edge of the case.
While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
4 человек успешно провели ремонт по этому руководству.
