Введение
A faulty wireless card can affect wireless connection. This guide will show the user how to replace the wireless card.
Выберете то, что вам нужно
Push the tabs on the left and right of the battery out towards the edge of the case.
While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
The card will lift up, remove the card by pulling the lifted edge away from you.
2 участников успешно повторили данное руководство.
