Введение
The Dell Latitude E6500 can experience multiple signs of RAM failure, including crashing, a blue background screen, and frequent freezing. However, it is easy to fix with basic tooling. Before beginning the repair, a user must have a size 0 screwdriver and an eight-gigabyte RAM memory card.
NOTE: use an anti-static wrist strap when working to prevent circuitry damage.
Выберете то, что вам нужно
Use a size JIS #0 screwdriver to remove the center screw.
Slide the back cover towards you to remove.
Push the first two hinges away from the RAM.
Remove first RAM card from the hinge.
Push the second two hinges away from the RAM to remove second RAM card.
