Введение
This guide will show you the process of removing and replacing the heat sink system in your Latitude E6510.
Выберете то, что вам нужно
Locate the tabs that lock the battery in place.
Push tabs towards each other while simultaneously pushing the battery away from the device.
Unscrew the screw located in the center of the back panel. Do not completely remove the screw, a spring will keep it in place when it has been loosened.
Slide the panel back until it unlocks.
Unscrew the two 5.5 mm screws securing the fan.
Lift the end of the fan opposite the copper wire up.
Pull the fan away from the device.
Locate and loosen the four silver screws holding down the heat redistribute component.
Do not competely remove the screws as springs keep the screws attached to the metal plate after you loosen them.
Lift the metal plate up on the end closest to the screws.
Slide the whole assembly away from where you removed the fan.
2 человек успешно провели ремонт по этому руководству.
