Введение
The steps in this guide will require a JIS #0 screw driver to remove 6 screws with a head size of approximately 4.36mm and length of 3.63mm.
Выберете то, что вам нужно
With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
Pry off the plastic keyboard trim. It is easiest to start at the bottom of the keyboard.
Lift the keypad up from the bottom.
Rest the keypad on the LCD screen for easy access during the next step.
Peel back the tape holding the ribbon connector.
Disconnect the ribbon and the keyboard will be free from the laptop.
Один комментарий
Hello,
Nice instructions, could someone please tell me what are the other conector/ribbions used for in this dell e6520 under the keyboard ? any help will most appreciated.
Thanks in advance
