Введение
The LCD (liquid crystal display) screen may need to be replaced if it is cracked or to improve resolution.
Выберете то, что вам нужно
With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
Gently pry the protective LCD cover from around the screen. You shouldn't have a problem just using your fingers.
Once all the screws have been removed, lay the screen down on the keyboard and disconnect the LCD cable.
Еще один человек закончил это руководство.
