Введение
This guide will walk users through replacing the Dell Latitude E6530 motherboard. Refer to troubleshooting page before beginning guide to determine and clarify the problem.
Выберете то, что вам нужно
Using a Phillips #1 Screwdriver, unscrew the button panel.
Life the button panel out of the Dell Latitude E6530.
Flip the computer onto it's back.
Remove the back panel.
Using a 1mm Philips Head Screwdriver, remove the screws indicated in the image.
Use a spludger to remove the keyboard.
To reassemble your device, follow these instructions in reverse order. If problem persists refer to troubleshooting guide and additional links.
