Dell Latitude E7270 Motherboard Removal
Выберете то, что вам нужно
  1. Dell Latitude E7270 Motherboard Removal, Back Panel: шаг 1, изображение 1 из 1
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Motherboard Removal: шаг 2, изображение 1 из 1
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 Motherboard Removal: шаг 3, изображение 1 из 1
    • Lift and remove the panel.
  4. Dell Latitude E7270 Motherboard Removal, Battery: шаг 4, изображение 1 из 1
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 Motherboard Removal: шаг 5, изображение 1 из 1
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 Motherboard Removal: шаг 6, изображение 1 из 1
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
  7. Dell Latitude E7270 Motherboard Removal, Cooling Fan: шаг 7, изображение 1 из 3 Dell Latitude E7270 Motherboard Removal, Cooling Fan: шаг 7, изображение 2 из 3 Dell Latitude E7270 Motherboard Removal, Cooling Fan: шаг 7, изображение 3 из 3
    • Remove the 4 pin fan power connector from the motherboard by using your finger and pulling up.
    • Remove the four M2.5 X 5MM screws that hold on the rectangular bracket located towards the center of the motherboard using a Phillips #00 screwdriver.
    • Remove the three M2.5 X 5MM screws that hold down the circular fan bracket using a Phillips #00 screwdriver.
  8. Dell Latitude E7270 Motherboard Removal: шаг 8, изображение 1 из 1
    • Lift and remove fan by pulling gently straight up using your fingers
  9. Dell Latitude E7270 Motherboard Removal: шаг 9, изображение 1 из 1
    • Before replacing fan, make sure to place a small amount of thermal paste to ensure proper heat dissipation and long term life.
  10. Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: шаг 10, изображение 1 из 3 Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: шаг 10, изображение 2 из 3 Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: шаг 10, изображение 3 из 3
    • Remove the 10 wire connections by using your fingers to separate the connections.
    • Remove the thirteen M2.5 X 5MM screws that fasten the motherboard using a Phillips #00 screwdriver.
    • Remove the two M2.5 X 8MM external screws that fasten the motherboard from outside using a Phillips #00 screwdriver.
  11. Dell Latitude E7270 Motherboard Removal: шаг 11, изображение 1 из 1
    • Lift and remove the motherboard by grabbing the outside edges and pulling straight up.
Заключение
Еще один человек закончил это руководство.
Jacob Clement
Участник с: 01/14/20
756 Репутация
Автор 6 руководств
Команда
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 30
За всё время: 2,687
