Введение
Before replacing your WLAN card, please refer to our Troubleshooting Guide. If your laptop is still not receiving a WiFi connection, but your other devices are, you will need to replace your WLAN card. Dell has made this process simple.
Выберете то, что вам нужно
Power off your laptop before starting.
Flip the device over so that the vents on the bottom are facing away from you.
Place your finger on the latch located in the center of the laptop.
Slide the latch to the right, applying enough force to reveal a red indicator.
Disconnect the white and black wires attached to the WLAN card by pulling them away from the card.
Remove a M2 x 3mm Phillips #0 screw from the WLAN card.
Gently pull the WLAN card out of its socket.
7 участников успешно повторили данное руководство.
