Введение
Before removing/replacing the Dell Latitude X300 hard drive, the battery, keyboard, and palm rest/trackpad will need to be removed.
Запчасти
Никакие детали не требуются.
  1. Before removing the battery from the laptop, make sure the power is off.
    • Before removing the battery from the laptop, make sure the power is off.
    • Push both battery locking clips outward at the same time.
  2. Slide the battery out of the laptop.
    • Slide the battery out of the laptop.
  3. Remove the four 4-mm screws on the bottom of the laptop using a #0 screw driver.
    • Remove the four 4-mm screws on the bottom of the laptop using a #0 screw driver.
  4. Carefully turn the laptop over and open the screen all the way. Locate the slot to remove the keyboard in the lower left hand corner.
    • Carefully turn the laptop over and open the screen all the way.
    • Locate the slot to remove the keyboard in the lower left hand corner.
    • Using a spudger as a lever, insert it into the slot and gently pry up.
  5. After the keyboard pops up, pull it away from the screen just enough to release the tabs.
    • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
    • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
  6. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  7. Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
    • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
  8. Remove the flexible ribbon from ZIF connector.
    • Remove the flexible ribbon from ZIF connector.
    • Do not pull on the ribbon to remove it from the ZIF connector.
  9. Position the laptop so that the bottom is facing upward.
    • Position the laptop so that the bottom is facing upward.
    • Remove the 3 #0 4 mm screws holding the bottom of the palm rest.
  10. Return the laptop to proper position and open the screen.
    • Return the laptop to proper position and open the screen.
    • Remove the 6 #0 4 mm screws holding in the palm rest.
  11. Gently lift the palm rest and rotate it outward so that the bottom is now facing up.
    • Gently lift the palm rest and rotate it outward so that the bottom is now facing up.
    • The ribbon attached to the track is short and extremely delicate. Use care when moving the palm rest.
  12. Lift up on the small ZIF connector and remove ribbon.
    • Lift up on the small ZIF connector and remove ribbon.
    • If ribbon seems stuck gently wiggle it to remove. Do not pull ribbon with great force.
  13. Remove the 4 #00 5 mm screws holding the hard drive to the case.
    • Remove the 4 #00 5 mm screws holding the hard drive to the case.
  14. Carefully pull up on the hard molded plastic portion of the ribbon to detach it from the computer.
    • Carefully pull up on the hard molded plastic portion of the ribbon to detach it from the computer.
  15. Remove the hard drive from the laptop.
    • Remove the hard drive from the laptop.
Заключение
2 участников успешно повторили данное руководство.
Taylor Bateman
Участник с: 20.01.2012
93 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 11-20, Maness Winter 2012 Member of Cal Poly, Team 11-20, Maness Winter 2012
CPSU-MANESS-W12S11G20
4 членов
Автор 7 руководств
Один комментарий
I have to know cause its long time ago i was using this pc,
and i really forgot my HD password and dont know where to find it,sorry
Bernard Vandenberghe - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 3
За 30 дней: 26
За всё время: 8,163
