Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Выберете то, что вам нужно
Carefully turn the laptop over and open the screen all the way.
Locate the slot to remove the keyboard in the lower left hand corner.
Using a spudger as a lever, insert it into the slot and gently pry up.
After the keyboard pops up, pull it away from the screen just enough to release the tabs.
Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
Position the laptop so that the bottom is facing upward.
Remove the 3 #0 4 mm screws holding the bottom of the palm rest.
Return the laptop to proper position and open the screen.
Remove the 6 #0 4 mm screws holding in the palm rest.
Gently lift the palm rest and rotate it outward so that the bottom is now facing up.
