  1. Turn the laptop over so that the bottom is facing up. Remove the two #0 3 mm screws holding the cover plate.
    • Turn the laptop over so that the bottom is facing up.
    • Remove the two #0 3 mm screws holding the cover plate.
  2. Push both metal retaining clips outward at the same time using your hands carefully.
    • Push both metal retaining clips outward at the same time using your hands carefully.
    • If done correctly the memory should pop up at a 45 degree angle.
  3. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  4. Gently pull the memory out of the retainer at the same 45 degree angle.
    • Gently pull the memory out of the retainer at the same 45 degree angle.
  5. Insert the new memory at 45 degree angle.
    • Insert the new memory at 45 degree angle.
  6. Ensure the memory is in all the way before pressing the memory downward until both metal retainer clips are snapped into place.
    • Ensure the memory is in all the way before pressing the memory downward until both metal retainer clips are snapped into place.
Заключение
To reassemble your device, reinstall cover plate with two #0 screws.
Thomas Wong
Участник с: 20.01.2012
23 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 11-20, Maness Winter 2012 Member of Cal Poly, Team 11-20, Maness Winter 2012
CPSU-MANESS-W12S11G20
4 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 2
За 30 дней: 4
За всё время: 2,019
