Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Запчасти
Детали не указаны.
  1. Make sure the Dell Latitude X300 power is off.
    • Make sure the Dell Latitude X300 power is off.
    • Remove the battery located on the bottom of the device by pushing in both clips.
  2. Remove rubber caps on each corner of the front screen with a pinch. Remove the 4 mm screws located on the front screen of the laptop.
    • Remove rubber caps on each corner of the front screen with a pinch.
    • Remove the 4 mm screws located on the front screen of the laptop.
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Купить сейчас
    Купить сейчас
  4. Carefully, remove the screen casing using either your hands or a proper tool.
    • Carefully, remove the screen casing using either your hands or a proper tool.
    • The casing is very flimsy, so extreme care is required.
  5. Remove the 4 mm screws on the bottom left and bottom right corner of the screen.
    • Remove the 4 mm screws on the bottom left and bottom right corner of the screen.
  6. Carefully lift the screen and place it on it's face. Disconnect the wiring attached to the screen.
    • Carefully lift the screen and place it on it's face.
    • Disconnect the wiring attached to the screen.
    • It is important not to damage this wire.
Заключение
3 участников успешно повторили данное руководство.
Jacob
Участник с: 12.03.2014
9 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 6-1, Vijaybhaskar Spring 2014 Участник UMass Dartmouth, Team 6-1, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S6G1
4 членов
Автор 2 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 555
