Выберете то, что вам нужно
Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
To close the case, simply press it closed until you hear the tabs click into place.
18 участников успешно повторили данное руководство.
Один комментарий
Thanks, couldn’t for the life of me figure out how to open the silly thing. :)
cool de faires des sites comme ca :)
baptiste Prando - Ответить
Excellent - Only comment - do the the green brackets come with a new hard drive or should I leave them inside the case for the next owner - Removing to donate to recycling
sheila_jones - Ответить
I got this yesterday....up and running now....how on earth do I MERGE the 18GB partition D with C....there is just NO option there.
Elvis 1357 - Ответить
Also, want to add another HD....but, there are no cables at all?
