Выберете то, что вам нужно
Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
Identify the Hard Drive in the case.
Remove the power cable from the hard drive by squeezing the side tabs in and pulling gently.
Remove the IDE cable from the hard drive by gently pulling the ribbon cable out.
8 участников успешно повторили данное руководство.
Один комментарий
I got this yesterday....up and running now....how on earth do I MERGE the 18GB partition D with C....there is just NO option there.
Also, want to add another HD....but, there are no cables at all?
