Dell OptiPlex GX260 Power Supply Replacement
Выберете то, что вам нужно
  1. Dell OptiPlex GX260 Power Supply Replacement, Case: шаг 1, изображение 1 из 2 Dell OptiPlex GX260 Power Supply Replacement, Case: шаг 1, изображение 2 из 2
    • Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
    • Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
    • Note: Some force may be required to push in the oval buttons open the PC case.
  2. Dell OptiPlex GX260 Power Supply Replacement, Power Supply: шаг 2, изображение 1 из 1
    • Locate the power supply in the case.
    • Disconnect the AXT power cable to the motherboard.
    • Disconnect the P4 12 volt power cable from the motherboard.
    • Disconnect the power cable from the optical drive.
    • Disconnect the floppy drive power cable.
    • Disconnect the hard drive power cable.
  3. Dell OptiPlex GX260 Power Supply Replacement: шаг 3, изображение 1 из 1
    • Remove the two Phillip screws holding the power supply into the the case and lift the power supply out.
    • When installing a new power supply ensure that the voltage selector is correctly set before you connect the mains cable.
    • Incorrect voltage settings will damage the power supply and may also cause other components to be damaged.
  4. Dell OptiPlex GX260 Power Supply Replacement: шаг 4, изображение 1 из 1
    • Push down on the green tab with one hand.
    • With your other hand, grip the top of the power supply and pull back and up to remove from the case.
Заключение
6 участников успешно повторили данное руководство.
Kevin Schapansky
Участник с: 10/05/10
1 457 Репутация
Автор 9 руководств
Команда
Cal Poly, Team 4-48, Amido Fall 2010 Участник Cal Poly, Team 4-48, Amido Fall 2010
CPSU-AMIDO-F10S4G48
4 членов
Автор 27 руководств
Один комментарий
In mine, the power supply was much longer due to a fan located on the front end. Same basic disassembly, however. There was a green tab at the front and it was difficult, but the power supply (with effort) did slide forward and out.
jknox - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 20
За всё время: 13,132
