Введение
In this guide, we will be removing parts of the computer from the motherboard to be able to take the board itself out.
Выберете то, что вам нужно
Disconnect all of the cords that are connected to the motherboard.
Press in the lever on the side of the male end, and then pull out.
Pull cord straight out.
Disconnect the front plate (USB and audio output) from the motherboard.
Remove the graphics card.
Lift the blue latch on the fat end of the graphics card.
Pull the blue lever on the skinny end of the graphics card toward the power supply.
Pull out one end of the card at a time.
Remove the heat sink.
Unscrew the (2) two screws using a Phillips #2 screwdriver and lift out the heat sink.
Remove the (5) five 6mm Phillips #2 screws from the motherboard.
Remove the (2) two 17mm Phillips #2 screws from the mount for the heat sink.
Remove the back plate by lifting straight out by the blue latch that secures the graphics card.
Pull the end of the motherboard closest to the back of the computer away from the static back plate.
Lift this end away and out of the case.
7 человек успешно провели ремонт по этому руководству.
