Введение
In this guide, we will show you how to take out the CPU (processor), and replace it with a new one.
Выберете то, что вам нужно
The processor is located inside the heat sink (indicated by the marker).
Unscrew the 9.5 mm screws from heatsink on both sides using the Phillips #2 screwdriver.
Push the small lever downwards, then sideways and upwards, in order to release it from the hook.
Remove the processor from its casing.
3 участников успешно повторили данное руководство.
