Dell Optiplex GX620 CMOS Battery Replacement
Выберете то, что вам нужно
  1. Dell Optiplex GX620 CMOS Battery Replacement, How to unplug and discharge before repair: шаг 1, изображение 1 из 2 Dell Optiplex GX620 CMOS Battery Replacement, How to unplug and discharge before repair: шаг 1, изображение 2 из 2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 CMOS Battery Replacement: шаг 2, изображение 1 из 2 Dell Optiplex GX620 CMOS Battery Replacement: шаг 2, изображение 2 из 2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 CMOS Battery Replacement, Dell Optiplex GX620 Side Panel Disassembly: шаг 3, изображение 1 из 1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 CMOS Battery Replacement, Removing the CMOS Battery: шаг 4, изображение 1 из 1
    • Insert a tool beside the battery and gently pry the battery out.
    • Using a screwdriver to pry open anything can harm your device. Instead, use a spudger or a plastic opening tool.
Заключение
To reassemble your device, follow these instructions in reverse order. Make sure you place the battery with the flat (positive) side facing up.
7 участников успешно повторили данное руководство.
Kristina
Участник с: 09/03/14
198 Репутация
Автор 7 руководств
Команда
Pasco Hernando, Team 5-1, Prince Fall 2014 Участник Pasco Hernando, Team 5-1, Prince Fall 2014
PHSC-PRINCE-F14S5G1
10 членов
Автор 15 руководств
2 Комментариев
Thank you for this. It gave me the courage to do the job, and told me how. I'm very, very grateful.
Richard Samuel - Ответить
Shouldn't the battery be listed in the parts? Squinting at the photo, it seems to be a CR2032?
vcayenne - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 8
За последние 30 дней: 52
За всё время: 15,451
