Введение
Replace the Dead Battery on the Motherboard
Инструменты
Запчасти
Детали не указаны.
Lay the computer on its side; you will see a blue knob.
Turn this knob 90 deg clockwise.
Slide the panel case forward about 1/2 inch while knob is turned.
Lift panel case off computer.
Unplug the blue cable that connects the hard drive to the motherboard.
Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
Under the hard drive, there is a circular, silver battery connected to the motherboard.
Use a spudger to gently pry the battery from the motherboard.
10 участников успешно повторили данное руководство.
Один комментарий
that particular battery holder looked hard to get out- no pop out lever, thought i’d break it gouging it out!
