Введение
Remove and Replace the Hard Drive
  1. Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Lay the computer on its side; you will see a blue knob. Turn this knob 90 deg clockwise.
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Slide the panel case forward about 1/2 inch while knob is turned. Lift panel case off computer.
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Unplug the blue cable that connects the hard drive to the motherboard. Unplug the blue cable that connects the hard drive to the motherboard.
    • Unplug the blue cable that connects the hard drive to the motherboard.
  5. Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view). Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
    • Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
  6. Squeeze the release tabs on either side of the hard drive.
    • Squeeze the release tabs on either side of the hard drive.
  7. Slide the Hard Drive out while squeezing the tabs. Slide the Hard Drive out while squeezing the tabs.
    • Slide the Hard Drive out while squeezing the tabs.
Заключение
6 участников успешно повторили данное руководство.
Wyatt
Участник с: 06.10.2010
763 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 22-4, Maness Fall 2010 Участник Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 членов
Автор 26 руководств
Комментариев: 2
Thanks for great tutorial.
Politers - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 5,674
