Предлагаемое руководство
Эта инструкция была специально выделена сотрудниками iFixit.
Введение
Перейти к шагу 1 ↓Replace the old RAM cards to greatly enhance computer speed.
Lay the computer on its side; you will see a blue knob.
Turn this knob 90 deg clockwise.
Slide the panel case forward about 1/2 inch while knob is turned.
Lift panel case off computer.
The RAM are the two green cards in the corner of the computer.
At each end of the card, there are two white clips securing the RAM to the Motherboard.
Push down both white clips with your thumbs until you hear a click.
The RAM cards can now be removed.
To reassemble your device, follow these instructions (steps 1-3) in reverse order.
8 человек успешно провели ремонт по этому руководству.
