Введение
If the keyboard is broken, missing, or malfunctioning you can replace the keyboard of the Dell Precision 5510 in 5 steps by following this guide.
Выберете то, что вам нужно
Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
Remove the 12 screws that secure the base cover to the computer.
There are two screws on each fan circled in the images shown. Use a Phillips #0 screwdriver to remove all four screws.
Each of the fans are plugged into the motherboard. Use tweezers to pull the plug out.
Carefully extract the fan from its housing bed. It should remove easily if all parts have been disconnected.
Remove all standalone motherboard screws.
8 screws with lengths of either 3.7mm or 4.65mm
