Введение
Replacing CPU fan P/N: 0F01PX
and GPU fan P/N: 0V9H8N
Выберете то, что вам нужно
Ensure that your work surface is flat and clean to prevent the computer cover from being scratched.
Turn off your computer.
Disconnect your computer from all the cables.
Close the display lid and turn the computer over.
Remove the M2x3 T5 screws that secure the base cover to the computer.
Turn the system badge flap over and then remove the M2x8.5 screws that secure the base cover to the computer.
Pry the edges of the base cover and lift it to remove it from the computer. Consider using a spudger.
Two case latches are approximately here.
Here.
There is a very small amount of space, so I didn't unplugged it fully, just removed from the socket. And made sure that there is no contact.
