Dell Precision 7710 Memory Module Replacement
Выберете то, что вам нужно
  1. Dell Precision 7710 Memory Module Replacement, Battery Cover: шаг 1, изображение 1 из 1
    • Slide the release latch to unlock the battery cover [1].
    • Slide and lift the battery cover to remove it from the computer [2].
  2. Dell Precision 7710 Memory Module Replacement, Battery: шаг 2, изображение 1 из 1
    • Slide the release latch to unlock the battery [1].
    • Lift and remove the battery from the computer [2].
  3. Dell Precision 7710 Memory Module Replacement, Base Cover: шаг 3, изображение 1 из 1
    • Remove the screws that secure the base cover to the computer [1].
    • Slide and lift the base cover away from the computer [2].
  4. Dell Precision 7710 Memory Module Replacement, KeyBoard: шаг 4, изображение 1 из 2 Dell Precision 7710 Memory Module Replacement, KeyBoard: шаг 4, изображение 2 из 2
    • Lift the tab and disconnect the 4 cables, one of the cables may be obstructed by the HDD, so you will need to unscrew/detatch the HDD tray first [1, 2].
    • Pry the keyboard trim starting from the bottom and work along the top edge and remove it from the computer.
  5. Dell Precision 7710 Memory Module Replacement: шаг 5, изображение 1 из 1
    • Remove the screws that secure the keyboard to the computer [1].
    • Lift the front side and slide the keyboard to remove it away from the computer [2, 3].
  6. Dell Precision 7710 Memory Module Replacement, Memory Module: шаг 6, изображение 1 из 1
    • Pry the retention clips away from the primary memory until it pops up.
    • Lift the primary memory and remove it from the computer.
  7. Dell Precision 7710 Memory Module Replacement: шаг 7, изображение 1 из 1
    • Remove the screw that secures the memory shield to the computer [1].
    • Lift and remove the memory shield from the computer [2].
    • Pry the retention clips away from the memory module until it pops up [3].
    • Lift the memory module and remove it from the computer [4].
Заключение
Еще один человек закончил это руководство.
Johnathan Hammond
Участник с: 02/28/18
45 555 Репутация
Автор 408 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
43 членов
Автор 1 994 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 21
За всё время: 2,104
