Dell Precision T3400 Optical Drive Replacement
  1. Dell Precision T3400 Optical Drive Replacement, Power down the PC.: шаг 1, изображение 1 из 1
    • If your PC is on, shut it down by navigating to the window tab in the bottom left corner, selecting the power icon, and then selecting shut down.
    • Unplug the PC from the wall.
    • Disconnect the power cable from the tower, unplug keyboards, monitors, or any other devices, and remove any USB devices.
    • Press the power button after completely shutting down the PC. This will "ground" the motherboard, preventing any short circuiting from occurring.
  2. Dell Precision T3400 Optical Drive Replacement, Remove the computer's side panel.: шаг 2, изображение 1 из 2 Dell Precision T3400 Optical Drive Replacement, Remove the computer's side panel.: шаг 2, изображение 2 из 2
    • Lay the computer on its side so the panel faces up.
    • Push the cover release latch at the back of the computer's case. The cover should pop off and away from the computer.
    • Make sure the computer is on its side before you begin replacing any parts.
  3. Dell Precision T3400 Optical Drive Replacement, Remove the front plate: шаг 3, изображение 1 из 1
    • Lift the front plate release lever, located toward the front of the PC.
    • While holding the front plate release lever up, slide the front plate towards the top of the case and remove it.
  4. Dell Precision T3400 Optical Drive Replacement, Remove the drive faceplate: шаг 4, изображение 1 из 1
    • Remove the drive faceplate by pulling down on the blue plate latch. The faceplate will pop off.
  5. Dell Precision T3400 Optical Drive Replacement, Disconnect the power and system board cables from the drive: шаг 5, изображение 1 из 1
    • Disconnect the power and system board cables from the back of the optical drive.
    • Pull on the connectors, not the wires, to remove the cables.
  6. Dell Precision T3400 Optical Drive Replacement, Remove the optical drive from its bay: шаг 6, изображение 1 из 1
    • Slide the plate latch down again to release the screw
    • While holding the plate latch down, push the drive out from behind, then pull it out of the bay
  7. Dell Precision T3400 Optical Drive Replacement, Slide the new drive into the now-empty drive bay: шаг 7, изображение 1 из 1
    • You should feel the drive click into place.
  8. Dell Precision T3400 Optical Drive Replacement, Reconnect the optical drive cables: шаг 8, изображение 1 из 1
    • Connect both the power and the system board cables to the optical drive.
    • Don't forget to plug the system board cable into the system board!
    • Make sure cables are not in the way of any fans.
Заключение
12 участников успешно повторили данное руководство.
Jenalina Santiago
Участник с: 09/08/13
1 426 Репутация
Автор 4 руководств
Команда
UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 Участник UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G2
3 членов
Автор 14 руководств
6 Комментариев
That's a great help.
I didn't realize I need to remove the front panel first. I spent 15 minutes still could not remove the drive. After I read this guide, I got it done in less than a minute!
sfacp2 - Ответить
Thanks for the help !!!
Alig0r
alig0r - Ответить
I have a dell optiplex gx 270 and parts from a demension 2400 ..... Change component or drive
Liz Ballard - Ответить
Plain and simple. Awesome! I knew I was missing a simple step (I didn't know the front plate had a release lever). With these steps, I was good in about 10 seconds tops.
Thanks!
davethemave1 - Ответить
Thanks for your plane explanation.
Han Voerman - Ответить
Thank you, really helped me out. Now I know where to find all the guides!
Lemon Snaps - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 10
За последние 30 дней: 30
За всё время: 14,838
