Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Выберете то, что вам нужно
If your PC is on, shut it down by navigating to the window tab in the bottom left corner, selecting the power icon, and then selecting shut down.
Unplug the PC from the wall.
Disconnect the power cable from the tower, unplug keyboards, monitors, or any other devices, and remove any USB devices.
Lay the computer on its side so the panel faces up.
Push the cover release latch at the back of the computer's case. The cover should pop off and away from the computer.
Lift the front plate release lever, located toward the front of the PC.
While holding the front plate release lever up, slide the front plate towards the top of the case and remove it.
Remove the drive faceplate by pulling down on the blue plate latch. The faceplate will pop off.
Disconnect the power and system board cables from the back of the optical drive.
Slide the plate latch down again to release the screw
While holding the plate latch down, push the drive out from behind, then pull it out of the bay
Connect both the power and the system board cables to the optical drive.
Don't forget to plug the system board cable into the system board!
12 участников успешно повторили данное руководство.
6 Комментариев
I have a dell optiplex gx 270 and parts from a demension 2400 ..... Change component or drive
Plain and simple. Awesome! I knew I was missing a simple step (I didn't know the front plate had a release lever). With these steps, I was good in about 10 seconds tops.
Thanks!
Thanks for your plane explanation.
