Введение
Symptoms that lead to replacement: The screen turns on and off immediately.
A recurring failure on many flat screens of all brands...
The 330uf35v105° capacitors are located too close to the heatsinks, so they blow out.
I suggest you replace them with more resistant little brothers, the 330uf35v135°
Выберете то, что вам нужно
You will need all the tools in the pictures:
Flat screwdriver, one large and one smaller
Phillips screwdriver, one large and one smaller
Small tip precision soldering iron
Tin
Small cutting pliers
A desoldering pump
Patience...
The most delicate part of the repair arrives. You are going to disconnect the most fragile tablecloth from the screen.
Once the tablecloth is disconnected, you can remove the metal cover from the screen. Well done the hardest part is done...
Take the metal cover.
Remove the 4 screws from the smaller of the 2 electronic cards (video card).
Unplug the only connected slot.
You can now remove the screws from the other electronic board (power board)
First, you must IDENTIFY the faulty capacitors... How? In this specific case, nothing could be simpler, since the capacitor was subjected to a temperature exceeding 105°C inside the screen, it burst.
Once the 6 capacitors have been changed, you can screw the power board back on and follow the tutorial in reverse...
I hope you and your Dell SP2208wft live long. Don't Throw Away, Fix!!! You can do it !!!
To reassemble your device, follow the instructions in reverse order.
Особая благодарность этим переводчикам:
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
