Введение
If you need to reinstall a new rear camera, follow this guide to access the motherboard and the camera. For this guide you will be needing a plastic opening tool, a Phillips #0 screwdriver, and tweezers.
Выберете то, что вам нужно
Place the device flat on its screen.
Using the plastic opening tools, pry open the top segment of the tablet where the camera is located.
Take the segment off and place it to the side.
Disconnect the no-fuss ribbon cable connector.
Remove the battery by gently lifting it out of the device.
Disconnect the no-fuss ribbon cable connector. Using tweezers, carefully pull the connector straight out of the socket.
Disconnect the delicate ribbon cable from the Zero Insertion Force (ZIF) Connector.
Using the tweezer, carefully wiggle off the camera attached to the base.
After it wiggles free, lift the camera away from the base of the tablet.
