Введение
If your speakers seem to be not in the best condition or broken entirely, use this guide to help change out your speakers. You will need a Phillips #0 screwdriver, a plastic opening tool, and tweezers.
Выберете то, что вам нужно
Place the device flat on its screen.
Using the plastic opening tools, pry open the top segment of the tablet where the camera is located.
Take the segment off and place it to the side.
Инструмент, используемый на этом этапе:Tweezers$4.99
Disconnect the no-fuss ribbon cable connector.
Remove the battery by gently lifting it out of the device.
Gently lift up the black covered wire and place it on the side, so that it is not in the way of the procedure.
When encountering a zero insertion force connector, the best way it to carefully use tweezers to flip up the white locking flap securing the blue-tipped ribbon cable.
Then, gently use the tweezers to pull out the blue-tipped ribbon cable from the unlatched connector.
Using the tweezers, carefully pull out the cable straight out of the no-fuss ribbon cable connector.
When dealing with a zero insertion force connector, the best way it to carefully use a tweezer to flip up the white locking flap holding the blue-tipped ribbon cable.
Then, gently remove the ribbon cable from the socket.
When dealing with a zero insertion force connector, the best way it to carefully use a tweezer to flip up the white locking flap holding the blue tip wire.
Then gently remove the wire from the socket.
Using the tweezers, carefully flip up the locking tab on the Zero Insertion Force connector.
Then, gently disconnect the orange ribbon cable.
After removing all the adhesive strips, gently lift up the sensor board as to not bend it.
When dealing with a zero insertion force connector, the best way it to carefully use a tweezer to flip up the white locking flap holding the orange ribbon cable.
Once the white tab is lifted, use the tweezer to carefully pull out the orange ribbon cable.
Using your fingers, wiggle the speaker until it comes free from the device. Carefully remove it from the tablet.
Using your fingers, wiggle the other speaker until it comes free. Carefully remove it from the tablet.
Еще один человек закончил это руководство.
