Dell Studio 1440 Hard Drive Replacement
Выберете то, что вам нужно
  1. Dell Studio 1440 Hard Drive Replacement, Battery: шаг 1, изображение 1 из 1
    • Slide the battery release latch until it clicks into place.
    • Slide the battery out of the battery bay.
  2. Dell Studio 1440 Hard Drive Replacement, KeyBoard: шаг 2, изображение 1 из 1
    • Turn the computer over and open the display.
    • Ease the keyboard surround up using your fingers or a plastic scribe.
  3. Dell Studio 1440 Hard Drive Replacement: шаг 3, изображение 1 из 1
    • Lift the keyboard surround off the computer.
    • Remove the two screws at the top of the keyboard.
    • CAUTION: The keycaps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
    • Carefully slide the keyboard out of the computer and turn it over as indicated in the following illustration.
    • CAUTION: Be extremely careful when removing and handling the keyboard. Failure to do so could result in scratching the display panel.
  4. Dell Studio 1440 Hard Drive Replacement: шаг 4, изображение 1 из 1
    • Release the keyboard cable connector latch and disconnect the keyboard cable from the system board connector.
    • For backlit keyboards, release the keyboard backlight cable connector latch to disconnect the keyboard backlight cable from the system board connector.
    • Lift the keyboard off the computer.
  5. Dell Studio 1440 Hard Drive Replacement, Hard Drive: шаг 5, изображение 1 из 1
    • Remove the four screws securing the hard drive assembly to the computer base.
    • Pull the black pull-tab to lift the hard drive assembly out of the computer base and disconnect the interposer from the SATA connector on the system board.
  6. Dell Studio 1440 Hard Drive Replacement: шаг 6, изображение 1 из 1
    • Remove the four screws securing the hard drive cage to the hard drive.
    • Pull the interposer to disconnect it from the hard drive.
    • Lift the hard drive off the hard drive cage.
Заключение
Johnathan Hammond
Участник с: 02/28/18
44 953 Репутация
Автор 408 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 985 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 359
