Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Here we'll cover how to remove the bottom hatch of the laptop, how to remove the drive caddy, and how to remove the actual hard drive.
Запчасти
Детали не указаны.
  1. Gather tools and materials Flip over laptop, and remove battery as a safety precaution Flip over laptop, and remove battery as a safety precaution
    • Gather tools and materials
    • Flip over laptop, and remove battery as a safety precaution
  2. If you look at the bottom of the laptop, you will notice that there is a panel that is removable Unscrew the screws that hold the panel in place Unscrew the screws until they are loose. They will not come out of the panel
    • If you look at the bottom of the laptop, you will notice that there is a panel that is removable
    • Unscrew the screws that hold the panel in place
    • Unscrew the screws until they are loose. They will not come out of the panel
    • After loosening all the screws, lift the panel up from the main chassis
    • You may need to use a flathead screwdriver to lift the panel
  3. Now we have access to the internals of the laptop, pretty neat If the battery is away from you, the hard drive should be closer towards you on the left Start by removing the screws holding the caddy into the chassis
    • Now we have access to the internals of the laptop, pretty neat
    • If the battery is away from you, the hard drive should be closer towards you on the left
    • Start by removing the screws holding the caddy into the chassis
    • These screws have a more rounded top, and are longer
    • Once loosened, you can remove with your fingers or tweezers, and then set them aside
  4. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  5. Now we remove the screws holding the drive to the caddy These screws are have a flatter head, and are shorter These are standard drive screws that are used to mount any hard drive to a mounting device, such as brackets to put it in a desktop computer
    • Now we remove the screws holding the drive to the caddy
    • These screws are have a flatter head, and are shorter
    • These are standard drive screws that are used to mount any hard drive to a mounting device, such as brackets to put it in a desktop computer
    • The manufacturer likes to put these in very tightly, and it may take some effort to remove. I suggest using a screwdriver with a bigger handle, not the one I am using
    • Set these screws aside, apart from the screws we removed in the last step
  6. Now that the screws are removed, the caddy can be removed from the chassis and drive Pull the black tab on the right side of the caddy, and pull up It might take some wiggling but it should come out
    • Now that the screws are removed, the caddy can be removed from the chassis and drive
    • Pull the black tab on the right side of the caddy, and pull up
    • It might take some wiggling but it should come out
  7. Now that the caddy is removed, we can lift the drive out of it's place It should lift out easily, but it will still be attached with a cable Set it aside on top of the optical drive (the metal surface)
    • Now that the caddy is removed, we can lift the drive out of it's place
    • It should lift out easily, but it will still be attached with a cable
    • Set it aside on top of the optical drive (the metal surface)
  8. Now that the drive is removed, we have to remove the cable connecting it to the motherboard It may be hard to do at first, but there are some groves that you can use to hold on to Pull the connector from the drive gently
    • Now that the drive is removed, we have to remove the cable connecting it to the motherboard
    • It may be hard to do at first, but there are some groves that you can use to hold on to
    • Pull the connector from the drive gently
    • Wiggling the connector a bit does help a little
  9. If you found it difficult to remove the drive or the cable connecting the drive to the motherboard, you can remove the whole cable at once If you look to the right of the drive, you will see another tab, this one is black, but I've also seen blue ones Pull this tab gently in order to remove the cable
    • If you found it difficult to remove the drive or the cable connecting the drive to the motherboard, you can remove the whole cable at once
    • If you look to the right of the drive, you will see another tab, this one is black, but I've also seen blue ones
    • Pull this tab gently in order to remove the cable
    • Again, wiggling also helps
  10. If you removed the drive using steps 1-7 then what you have should be left in picture 1 If you had trouble removing the drive, and you went through to step 8, then the parts remaining  will be in picture 2
    • If you removed the drive using steps 1-7 then what you have should be left in picture 1
    • If you had trouble removing the drive, and you went through to step 8, then the parts remaining will be in picture 2
    • The drive should have a SATA interface, so you should be able to mount it into another computer using 2.5" to 3.5" converter brackets and a SATA cable
Заключение
12 участников успешно повторили данное руководство.
Eric Bentley
Участник с: 14.05.2011
1 333 Репутация
Автор 3 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 15
За всё время: 19,717
