Введение
This guide will show you how to remove the bottom panel, remove the RAM, and replace it properly. It's easier than you think, and takes minimal effort.
Выберете то, что вам нужно
Gather materials and supplies
Flip laptop over
Remove battery as a safety precaution
Unscrew the screws holding the panel on the underside of the laptop
Remove the panel on the bottom of the laptop
The screws will loosen but they will not come out, this is normal
Sometimes a flat object like a flathead screwdriver is necessary to remove the panel
Set the panel aside
Locate the memory. It should be very easy to find. It will be on the right side of the hard drive, and will look like the picture (Depending on the type of memory your system came with, it may be a different color or style)
Now we'll remove one stick of memory; we'll start with the one on the top (assuming the battery is further away from you)
On each side of the stick you will see two metal tabs
Press these tabs outwards in order to release the RAM
Press these tabs gently. I haven't broken one, but they do look very weak
The slot is spring loaded, and once the tabs are properly opened, it should spring up at an angle
In order to actually remove the stick, simply pull it outwards of the slot
It may be in a bit tight, wiggling it out is helpful
The same process is repeated for the second stick of RAM
This time it will spring up the opposite direction
Place it off to the side as well, remembering which slot it was in
Now the memory has been successfully removed
Remembering which slot the RAM was in saves time and effort
Each stick has a grove where the pins are, and the slot has a corresponding notch in it
Remembering which one goes where saves you time when re-installing the memory
4 участников успешно повторили данное руководство.
