Введение
The Wi-Fi card on a computer is the key component when it comes to connecting to the internet. Most Wi-Fi cards are easy to remove or replace if needed, and the Dell Studio 1558's Wi-Fi card is no different. Care has to be taken in order to avoid damaging the connectors.
Выберете то, что вам нужно
Unscrew the three screws (Phillips #0) on the back panel to reveal the innards underneath the panel. It is helpful to keep these screws in the holes of the back panel.
Pry the back panel off and set aside.
Disconnect the WLAN (Wi-Fi) antenna cables.
Gather the antenna cables (black, white, and grey) and unwind them from the clips they are pinned under to keep them from rattling around.
Remove the single screw (Philips #0).
