Введение
This replacement guide will show you how to replace the auxiliary (aux) cord on your Dell VRP100 headset. Most audio-related issues will stem from the aux cord so it is important to replace it to ensure the highest audio quality.
Выберете то, что вам нужно
Remove the black foam padding by peeling away slowly.
Remove the front and back padding from the headset by peeling away slowly.
Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
Carefully remove the lens and motherboard assembly from the white casing.
Remove the four 2.5mm PH000 screws by rotating counter-clockwise.
Separate the lens housing from the motherboard panel.
In the top right corner of the motherboard panel, peel back the yellow tape covering the bundled auxiliary cable connector using tweezers.
Carefully pull out the bundled cable connectors.
Еще один человек закончил это руководство.
