Введение
This replacement guide will show you how to replace the cover panel on your Dell VRP100 headset. With the right tools, this replacement is very simple, and is the basis to replacing many more components of your headset.
  1. Remove the black foam padding by peeling away slowly. Remove the front and back padding from the headset by peeling away slowly. Remove the front and back padding from the headset by peeling away slowly.
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
  2. Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
  3. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing. Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing. Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
  5. Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise. Carefully remove the lens and motherboard assembly from the white casing. Carefully remove the lens and motherboard assembly from the white casing.
    • Carefully remove the lens and motherboard assembly from the white casing.
Заключение
Marco Salazar
Участник с: 08.10.2018
270 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S17-G1, White Fall 2018 Member of Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 10
За всё время: 130
