Введение
Many components are connected to the motherboard so confirm that all of the components work before you decide to replace the whole motherboard.
Выберете то, что вам нужно
Remove the battery by pulling it from the edges and carefully peeling it off of the base.
Use a spudger to remove the ribbon cable that is around the speaker wire.
Disconnect the speaker wire from the motherboard by prying the connector upwards with the spudger.
Disconnect the two remaining connections on the motherboard.
To remove the first connector, lift up the clasp and remove the ribbon cable.
To remove the second one, use a spudger to gently pry the connector from the motherboard.
8 участников успешно повторили данное руководство.
2 Комментариев
unable to open the lock, can the mother board be changed
Great article.
