Введение
If you want to replace the speaker you must first get a new one. Once you do, then you are ready to follow these easy steps.
Выберете то, что вам нужно
Remove the battery by pulling it from the edges and carefully peeling it off of the base.
Use a spudger to remove the ribbon cable that is around the speaker wire.
Disconnect the speaker wire from the motherboard by prying the connector upwards with the spudger.
2 участников успешно повторили данное руководство.
