Введение
If your camera isnt functioning properly, not showing a display, or looks cracked or foggy, it may need to be replaced. In this guide we will be replacing the rear-facing camera.
Выберете то, что вам нужно
Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
Remove the back panel of the device.
Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
4.45mm Silver screws
3.6mm Black screws
Gently snap the perimeter clips open, and remove the internal plastic case.
Use the plastic opening tool to disconnect the camera from the logic board, by prying it up.
Еще один человек закончил это руководство.
