Dell Vostro 1320 Keyboard Replacement
Выберете то, что вам нужно
  1. Dell Vostro 1320 Keyboard Replacement, Keyboard: шаг 1, изображение 1 из 2 Dell Vostro 1320 Keyboard Replacement, Keyboard: шаг 1, изображение 2 из 2
    • Turn the computer over to remove the battery.
    • Slide the battery lock into the unlock position to release the battery.
    • Pull the battery out of it's slot while holding the battery lock open.
  2. Dell Vostro 1320 Keyboard Replacement: шаг 2, изображение 1 из 2 Dell Vostro 1320 Keyboard Replacement: шаг 2, изображение 2 из 2
    • The hinge cover needs to be removed next. This can be done by using a plastic opening tool.
    • Take the plastic opening tool and insert it into the grove below the hinge cover.
    • Firmly leverage the plastic opening tool under the hinge cover and pull up. It should make a popping noise. Repeat these steps on the other hinge.
  3. Dell Vostro 1320 Keyboard Replacement: шаг 3, изображение 1 из 2 Dell Vostro 1320 Keyboard Replacement: шаг 3, изображение 2 из 2
    • Once both hinges are loosened open the computer up fully.
    • Use your plastic opening tool to loosen the plastic hinge cover located above the keyboard. Start on one side and work your way over to another.
  4. Dell Vostro 1320 Keyboard Replacement: шаг 4, изображение 1 из 1
    • Once the plastic cover is removed, you need to locate the two screws holding the keyboard in place. The left one is located just above the escape key and the right one is located just above the delete key.
    • Use a number 0 bit driver to unscrew those.
    • If you did not remove the screws with a magnetic screw drivers then leave them in place and lift the keyboard itself up slowly to get them out safely.
  5. Dell Vostro 1320 Keyboard Replacement: шаг 5, изображение 1 из 3 Dell Vostro 1320 Keyboard Replacement: шаг 5, изображение 2 из 3 Dell Vostro 1320 Keyboard Replacement: шаг 5, изображение 3 из 3
    • Before you can completely remove the keyboard from the computer you must detach the keyboard ribbon cable.
    • To do that you must put your finger slightly underneath the black bar and pull up slightly.
Заключение
Christie Lloyd
Участник с: 08/26/15
431 Репутация
Автор 4 руководств
Команда
Western Carolina University, Team 1-4, Virtue Fall 2015 Участник Western Carolina University, Team 1-4, Virtue Fall 2015
WCU-VIRTUE-F15S1G4
4 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 1,211
