Введение
Steps on how to take out and replace the RAM drive. Follow these steps for the easiest possible way to take out and replace the RAM drive.
Выберете то, что вам нужно
After flipping over the laptop, the battery is on the bottom side of the laptop.
Find the tabs on both the left and right side of the battery.
Loosen the three 3 mm screws on the RAM cover.
Lift the cover and remove it from the laptop.
Pull tabs apart on both the top and bottom of the memory card.
Lift memory card and remove it from the laptop.
Repeat the process for the second memory card.
Еще один человек закончил это руководство.
