Введение
This guide will show you the proper steps to replace your speakers in your Dell Vostro 1400 Laptop.
Computer speakers allow any audio played to be transmitted out loud without the use of headphones. Speakers that are not functional will produce either distorted sound or no sound at all.
Before using this guide, make sure to remove the hard drive, the battery, and the RAM.
Before beginning, make sure the device is powered off and disconnected from any power source.
Выберете то, что вам нужно
After flipping over the laptop, the battery is on the bottom side of the laptop.
Find the tabs on both the left and right side of the battery.
Unscrew both screws on the hard drive panel until the panel is able to be removed.
Once screws have been loosened, remove the panel from the laptop.
Remove the hard drive by pulling up on the black tab on the right side of the hard drive.
Loosen the three 3 mm screws on the RAM cover.
Lift the cover and remove it from the laptop.
Pull tabs apart on both the top and bottom of the memory card.
Lift memory card and remove it from the laptop.
Repeat the process for the second memory card.
Loosen the 3 screws holding down the panel for the CPU processor door.
Loosen the 4 heat sink screws and lift the heat sink away from the motherboard.
Use a flat head screw driver to turn the CPU locking screw counter clockwise to 180 degrees.
Lift CPU processor away from the motherboard
Remove the seventeen 8mm bottom base screws.
Remove the two 8mm screws from the back.
Turn over the laptop and open it.
Using a flat head screw driver, pry up the power button cover starting right to left.
Unscrew the (2) 2mm x 3mm screws.
Carefully lift the keyboard and hold it over the power button.
Carefully lift up the blue latch on the keyboard cable connector and slide the cable out.
Unplug the WLAN antenna cables.
Unscrew the 2mm x 3mm screw.
Remove the WLAN card from the motherboard.
Remove the 2mm x 3mm screw on the media button circuit board.
Loosen the media button circuit board and take the antenna cables from under it.
Remove the (2) 2mm x 3mm screws.
Lift the motherboard out of the base and flip it over.
Remove the two 2.5mm x 5mm Right and Left speaker screws
Lift the speakers away from the base of the laptop.
Еще один человек закончил это руководство.
