Dell Vostro 15 3565 Hard Drive Bracket Replacement
Выберете то, что вам нужно
  1. Dell Vostro 15 3565 Hard Drive Bracket Replacement, Battery: шаг 1, изображение 1 из 1
    • Slide the release latch to unlock the battery [1].
    • Remove the battery from the computer [2].
  2. Dell Vostro 15 3565 Hard Drive Bracket Replacement, Optical-Disk Drive: шаг 2, изображение 1 из 1
    • Remove the screw that secures the optical drive to the computer [1].
    • Using a plastic scribe push the tab to release the optical drive [2].
    • Slide the optical drive out of the computer [3].
  3. Dell Vostro 15 3565 Hard Drive Bracket Replacement, KeyBoard: шаг 3, изображение 1 из 1
    • Release the keyboard by prying on the keyboard release tabs by using a scribe.
  4. Dell Vostro 15 3565 Hard Drive Bracket Replacement: шаг 4, изображение 1 из 1
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [1,2].
  5. Dell Vostro 15 3565 Hard Drive Bracket Replacement: шаг 5, изображение 1 из 1
    • Disconnect the keyboard cable from the system board [1].
    • Lift the keyboard cable to remove it from the computer [2].
  6. Dell Vostro 15 3565 Hard Drive Bracket Replacement, Base Cover: шаг 6, изображение 1 из 1
    • Disconnect the optical drive connector and lift it to remove it from the system board [1,2]
    • Remove the screws inside the palmrest [3].
  7. Dell Vostro 15 3565 Hard Drive Bracket Replacement: шаг 7, изображение 1 из 1
    • Remove the screws that secure the base cover to the computer [1].
    • Pry the edges of base cover and lift it to remove it from computer [2].
  8. Dell Vostro 15 3565 Hard Drive Bracket Replacement, Hard Drive: шаг 8, изображение 1 из 1
    • Disconnect the hard drive cable from the connector on the system board [1, 2].
    • Remove the screws that secure the hard drive assembly to the computer [3].
    • Lift the hard drive assembly away from the computer [4].
  9. Dell Vostro 15 3565 Hard Drive Bracket Replacement, Hard Drive Bracket: шаг 9, изображение 1 из 1
    • Pull the hard drive cable connector to remove it from the hard drive [1].
    • Remove the screws that secure the hard drive bracket to the hard drive [2].
    • Lift the hard drive from the hard drive bracket [3].
Заключение
Johnathan Hammond
Участник с: 02/28/18
45 237 Репутация
Автор 408 руководств
Команду
RampUP America, Inc. Участник RampUP America, Inc.
Community
43 членов
Автор 1 985 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 87
