Выберете то, что вам нужно
Slide the release latch to unlock the battery [1].
Remove the battery from the computer [2].
Remove the screw that secures the optical drive to the computer [1].
Using a plastic scribe push the tab to release the optical drive [2].
Slide the optical drive out of the computer [3].
Release the keyboard by prying on the keyboard release tabs by using a scribe.
Slide and lift the keyboard to access the keyboard connector cable under the keyboard [1,2].
Disconnect the keyboard cable from the system board [1].
Lift the keyboard cable to remove it from the computer [2].
Disconnect the optical drive connector and lift it to remove it from the system board [1,2]
Remove the screws inside the palmrest [3].
Remove the screws that secure the base cover to the computer [1].
Pry the edges of base cover and lift it to remove it from computer [2].
Disconnect the hard drive cable from the connector on the system board [1, 2].
Remove the screws that secure the hard drive assembly to the computer [3].
Lift the hard drive assembly away from the computer [4].
