Dell Vostro 15 5568 Hard Drive Replacement
Выберете то, что вам нужно
  1. Dell Vostro 15 5568 Hard Drive Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Remove the screws that secure the back cover to the computer.
  2. Dell Vostro 15 5568 Hard Drive Replacement: шаг 2, изображение 1 из 1
    • Using a scribe, pry the edges of the back cover from all sides [1].
    • Lift the back cover from the computer [2].
  3. Dell Vostro 15 5568 Hard Drive Replacement, Battery: шаг 3, изображение 1 из 1
    • Disconnect the battery cable from the connector on the system board [1].
    • Remove the screws that secure the battery to the computer [2].
    • Lift and remove the battery from the computer [3].
  4. Dell Vostro 15 5568 Hard Drive Replacement, Hard Drive: шаг 4, изображение 1 из 1
    • Lift the tab to disconnect the hard drive cable from the connector on the system board [1] .
    • Remove the screws that secure the hard drive to the computer [2].
    • Lift the hard drive from the computer [3].
Заключение
4 участников успешно повторили данное руководство.
Johnathan Hammond
Участник с: 02/28/18
44 953 Репутация
Автор 408 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 985 руководств
2 Комментариев
Did work for me, many thanks. Only two small remarks.
a) Why remove the battery? I was installing a SSD in addition to the built in one (the hdd place was still empty). Attaching the hdd cable is possible without battery removal.
b) Disonnecting the battery showed to be a bit tricky. Pulling the cable is out of question, and pulling at the label part looked also not advisable. One-sided prying…not so good. Pushing the connector in the plane of the battery - need to be very careful, slipping may mean impulse force to the cable. I used careful two sided prying into the small spaces left and right of the connector.
Wolfgang - Ответить
Cuál es el tamaño de los tornillos de la cubierta posterior?
Elisa de Torres - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 11
За всё время: 3,609
